Reply
Occasional Contributor
Canon LCD display
Hello, I just noticed last night that while taking pictures from my Canon 5D Mark I, the LCD display is showing a couple of blue lines, top and bottom, please see picture attached.
I don't know what I did but this is the first tie I'm seeing this.
Can anyone help me or let me know how to clear these lines.
Thank you for your assistance and guidence.
Esteemed Contributor
Re: Canon LCD display
What are you looking at? A Photo or Video? It looks like the aspect ratio has been changed, so the LCD is letterboxed.
Thank you for the reply. Working on photod only. How I can fix it?
Do you have a different aspect ratio set? Set it back to 3:2.
(If you are not sure, tell us the pixel dimension of the image)
Sorry for my ignorance but I don't know if I have a different aspect ratio and I don't know how to set it back to 3:2. Just shooting in RAW
Honored Contributor
Quoted from a help post for a 7D mark II.
"You've probably enabled the the aspect ratio info in the custom functions. Go to C.FN IV function 4 and select OFF.
Press the menu button, go to the next to the last menu on the right with the selection stick, then use the back wheel to move down to C.Fn IV Operations/Others and then press set. If the top selection (off) is not highlighted then that is you problem. Press the set button again, use the back wheel to select it, then press set again."
Go into your menu system and see if you have a similar setting.
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
The menu on the Canon %D is totally different than the 7D Mark II.
I cannot locate a function to change the aspect ratio.
Honored Contributor
You could always just clear all camera functions and it will reset camera back to factory settings. Then if you still see the blue lines it might indicate a camera malfunction.
Will do and thank you again for your assistance.
Honored Contributor
@Tustinman wrote:
The menu on the Canon 5D is totally different than the 7D Mark II.
It sounds as though you don't have an instruction manual. You can download one from Canon's Web site.
That said, I'm not 100% certain that the Mark I even has an aspect ratio setting. But if it does, the instruction manual should tell you.
Bob
powered by Lithium
