10-27-2020 10:13 AM
Hi new owner of a Canon EOS RP. Recently upgraded from a Canon 6D. I've been researching and testing out hss on the RP. Although, post firmware version, top banding has been fixed but I still see striped banding across the image at shutter speeds 1/1000th and above. Is there a workaround for this? I'm using the Godox flash system: Xpro-C for the trigger, 2 AD200s and an off-brand speedlite with the X1R-C as a receiver for the speedlite.
10-27-2020 10:33 AM - edited 10-27-2020 10:51 AM
Does the exact same external flash setup work on the 6D without the striped banding?
Please show us an example of the striped banding. Could it be a from CFL or LED lighting?
Examples of CFL and LED lighting banding:
