08-15-2016 01:05 PM
Battery has been replaced and still will not turn on. Any suggestions?
08-15-2016 01:16 PM
@Bacon2016 wrote:Battery has been replaced and still will not turn on. Any suggestions?
Contact Canon U.S. Support at 1-800-OK-CANON.
08-15-2016 01:21 PM
Thank you.
08-15-2016 01:20 PM
The customary suggestion is to carefully check the battery door. If it doesn't close properly, or if the mechanical switch that tells the camera that it's closed is jammed or broken, the camera will probably not turn on.
08-25-2016 02:38 AM
