Reply
Occasional Contributor
Canon 90D with Sigma 70-200 overexposes all pictures taken through the viewfinder (live view ok!)
I'm the happy owner of a Canon 90D. I have just bought a Sigma 70-200 lense, and I noticed that all pictures taken through the viewfinder are overexposed, no matter what I do. If I want to have a picture that is close to reality, I have to compensate the exposition with -2/-3. Tha't's a lot, not just "fine-tuning". With the other lenses, I never had this problem: Sigma 18-35mm f1.8, Canon 50mm f1.8...
Is that Sigma firmware problem? 90D firmware problem?
Esteemed Contributor
Re: Canon 90D with Sigma 70-200 overexposes all pictures taken through the viewfinder (live view ok!
Since Sigma has to reverse engineer the lens mount to get it to work, it must be a Sigma issue.
Is the aperture wide open when measuring the exposure? Try the depth of field preview button to see if the viewfinder lightens and darkens.
Yes, I've been taking test pictures at aperture wide open: f2.8.
And apprently the depth of field preview button works just fine: when I press on it the viewfinder darkens when I increase the aperture f-number. And depth of field increases in the same time.
Someone mentioned having the same problem years ago with another Sigma lense, and that it was solved with a Canon 90D firmware update.. Could that be a body firmware has to be updated in order to offer support for lenses that appeared after the firmware release?
VIP
Go to the Sigma support site.
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
[ Edited ]
Bravo John!
@phillipeliang, you'll need a Sigma USB dock.  Great investment if you own one or more of Sigma's Global vision lenses.
~6D2(v1.1.0) ~Many Lenses ~DxO PhotoLab Elite ~Windows10 Pro ~EVGA RTX 2080 FTW3 Ultra ~Pixma Pro-100 ~ImageClass MF644Cdw ~LBP622dw
Hi John, yes, I saw this firmware update (which I have) and the description, but either it "optimizes" a situation which is even worse or - more likely - it doesn't work for me. I still have an exposure problem through the viewfinder.
I love this USB dock, and I have used it a lot for the past weeks, for calibrating my Sigma lenses. A great investment, yes!
[ Edited ]
I found the culprit: it's the 90D body. A test with another 90D body shows the lens works great. I guess some hardware must be faulty, because cleaning configuration and even re-flashing the same 1.1.1 firmware did not help.
But still, that's strange: other lenses have no problem on this 90D body, only the 70-200.
[ Edited ]
Maybe the problem is not a hardware problem on one of my 90Ds. I took the time to make tests, with two 90Ds and 3 lenses:
Sigma 70-200
Canon 50
Sigma 18-35
It shows the problem is Sigma-specific, when taking pictures through the viewfinder. And apparently not all 90Ds are equal: some overexpose more than others. It really looks like a complex Sigma firmware bug.
VIP
"It really looks like a complex Sigma firmware bug."
I can't tell you any useful info about using the Siggy lens on a 90D since I don't own one but I can tell you the Sigma 70-200mm f2.8 zoom lens works perfectly on both my 1D Mk IV and 1DX.
You might want to reset your 90D back to factory default.  You could have a setting incorrectly set and not be aware of it. Make sure you clear all "custom" settings when you do the reset.  That is probably where the error might be.
powered by Lithium
