08-29-2020 07:56 PM
Got a new 90D the other day and I'm having a problem getting it to connect to my laptop via USB cable. I know what you're going to say "Make sure wi-fi is disabled!" been there, done that. Has anyone had the same problem in the past? If so, what did you do to fix it?
08-30-2020 06:08 AM
It would help to know what type of "laptop", Windows or MAC. Does it have an Intel Chipset?
Did the camera come with a USB cable? Canon seems to have stopped shipping cameras with USB cables. They seem to want push wireless connectivity. A "bad" USB cable is not unusual.
I suggest that you try a different USB cable, and make sure it is a data cable, not a power cable. Also, you want to try different USB ports. USB port expanders seem to work poorly with the cameras. Some laptops use them for the extra USB ports, but only one port is actually coming from the motherboard. That is the one you want!
08-30-2020 06:08 AM
09-03-2020 10:06 AM
Thanks, Waddizzie! The cable I was using was a power cable. All good now!
08-30-2020 06:44 PM
