Reply
Occasional Contributor
Canon 80d
So I was taking pictures last night and I turned off the camera and then turned it on again to take more and all of a sudden the squares won't go red anymore to focus. I tried on AV and manual and the squares just won't focus any more.. Anyone know how I can fix it. These are the settings 20190713_103505.jpg
Frequent Contributor
Re: Canon 80d
[ Edited ]
In dim lighting, the autofocus points that are used to establish focus flash red in the viewfinder of your EOS 80D when you initiate autofocusing. If you find them distracting, you can turn them off; if you instead want them to appear even in bright light, you can make it so. The control that adjusts this behavior is VF Display Illumination, which is Custom Function 15 in the Autofocus section. You get three choices:
  • 0: Auto: This is the default; the focus points flash red only in dim lighting.
  • 1: Enable: Here’s the option to select if you always want to see the focus points flash red.
  • 2: Disable: Okay, you’ve probably figured this one out already. But do note that even if you choose Off, you still see the red AF points light up when you’re using an AF Area mode that enables you to select a specific point or zone. Otherwise you wouldn’t know what AF point you were selecting.
Just set to enabled https://www.dummies.com/wp-content/uploads/9781119291367-fg1110.jpg
VIP
Re: Canon 80d
It looks pretty dark and dim in that room.  The camera may not have enough light for the AF system to lock on a subject.  Take the camera to well lit location and try it again.  Shooting outdoors on a sunny day would be ideal.
If it dos not work on a sunny day, then you probably have an issue with the camera.  Try to reset the camera back to factory defaults.  If a Reset does not cure it, contact Canon Support.
Re: Canon 80d
I've always used the camera in the room and low light and the red focus points always go red
Honored Contributor
Re: Canon 80d
Before you dismiss Waddizzle's point, remember that no camera has a dynamic range as great as that of the human eye. It may be that the camera has a better sense of how dim the room is than you do.
Bob
Respected Contributor
Re: Canon 80d
The red square is not going to be displayed in AI Servo mode.  You need to be in the regular mode.
Diverhank's photos on Flickr
Re: Canon 80d
Good catch!
Re: Canon 80d
I tried also in one shot mode and still couldn't get focus to work. I'll try to do the factory reset
VIP
Re: Canon 80d
Why don’t you take the camera to well lit location?  While you are it, remove that thing from the flash shoe.  Something is definitely wrong becase both shutter speed and aperture seem to be highlighted at the same time.
Re: Canon 80d
I'll try it outside or with the lights on and I'll take off the thing from the hot shoe and see if it helps
powered by Lithium
