12-03-2013 12:38 AM
Hey Folks,
I'm trying to set up two flashes off camera and I'm running into a strange problem. I'm controlling the 430ex via the wireless and driving the external wireless trigger via the sync port. Things work fine for a while, but after a while the sync port trigger stops triggering. The 430 continues to fire. If I close the on-board flash, the sync port starts working again. Popping it back up causes it to stop again. It continues this way until I power cycle the camera at which point it starts working again.
Has anyone seen anything like this?
I really like being able to control the 430 via wireless, but I've got the light balanced for two flashes, not one.
Any thoughts?
Thanks,
Mike
12-08-2013 09:49 AM
Hi mcmurdie!
Thanks for posting.
Multiple flash firing methods cannot be used at the same time. If you have something connected to the PC Terminal, it will not work when the built-in flash is used or when a flash is attached to the hotshoe. Only one can be used at a time.
