09-02-2020 09:43 AM
09-02-2020 08:22 PM
Check if its stuck becasue of a substance or a piece of sand. Try using a business card corner and run it around the button to see if that helps.
I had that problem once and it freed up the button using that approach.
09-03-2020 12:56 AM
Hi there,
I think the business card around the edges suggestion is a good one. Otherwise, the button may no longer be flush with it's switch like you said and repair would be necessary to resolve it.
https://www.usa.canon.com/internet/portal/us/home/support/service-repair
