08-30-2014 02:02 PM
Help, please?
Auto focus on my Canon 70D is not working in P,T, A, and M mode, while working perfectly in Auto, CA and SCN mode.
I have to press the back button AF-on to focus when taking a picture. But if I use live view the auto focus is working normally.
I believe that pressing the shutter button half way should always start focusing, also for the T, A , M and P mode?
I tried restoring the factory settings but it does not help a thing.
Is there somewhere some setting I should change, am I thinking wrong or is my camera not working properly?
Thank you for any help!
Regard, Gerard
08-30-2014 07:38 PM
Hi Gerard,
The 70D (like many of the Canon DSLRs) has customization options to assign which button(s) perform the auto focus (AF) start function. It sounds like these options may have been changed from their original default settings.
To see if that is the case, check the settings for C.Fn III on your camera. See pages 383 - 386 of your manual. You may see that your shutter button is no longer set to perfom AF start.
You can reset those C.Fn III-4 setting to their original default settings by pressing the "trash can" icon while in the menu screen shown in step 3 on page 383. See the note in blue at the bottom of that page.
And note that the "Clear All Camera settings" option shown on page 61 of the manual will not reset custom functions. So that may explain why your restore settings attempt earlier didn't help.
Bill
08-30-2014 04:00 PM - edited 08-30-2014 04:01 PM
08-31-2014 05:22 AM
Thank you Scott. My problem is solved, for some reason the shutter button had another function.
But thanks anyway for thinking about this!
regards, Gerard
08-30-2014 07:38 PM
Hi Gerard,
Bill
08-30-2014 08:49 PM
Hello Bill, thank you for your answer.. It is exactly as you explained: for some reason the shutter button had another function, no idea how I managed to change it. But I went to that menu option and pushed the trash button. And my problem is solved!
As I already had to send my camera back to Canon once, I was affraid to have to do it again. But no, it was only my ignorance.
many thanks for your help!
regards from the Netherlands, Gerard
08-31-2014 11:35 AM
Gerard, you're welcome! Glad I was able to help and that your camera is sorted now without having to go back to Canon. I love that the DSLRs these days have so much power and so many features. But as a result they are also complicated and can be frustrating when something doesn't seem to be working as expected. 🙂
Bill
01-10-2021 12:12 PM
