Reply
VIP
Re: Canon 70D Pink flashing problem
@Timberr wrote:
Yeah its nasty isnt it! I was worried about the potential for it being something to do with the image sensor. Stills are fine with it, Ive had no problem at all with them..so far, fingers crossed! Only when shooting video and only the last 2 shoots
Check your manual to see what the overheating icons look like.  The icons should also flash when shutdown is imminent.
Good luck, just the same.
Moderator
[ Edited ]
Good point! A hot sensor can cause problems with the image quality, but you should see the "Internal Temperature" warning icons. I've attached a screenshot from the manual page 287 (you can download the whole manual HERE.)
I realized those are hard to see. Here are the actual icons:
Respected Contributor
@Timberr wrote:
Hi folks
Anyone seen this issue before? Just started on my 70D the other day, very sporadic but incredibly annoying. I thought it was just flashes but it effects all the black in the shot as shown on this raw file I uploaded to Vimeo. The flashing happens on the screen when recording and is on the file which woudl tend to rule out purely a screen problem. Cant seem to find too many answers online so far.
https://vimeo.com/222956386
Any help would be much appreciated
Cheers
Tim
Looks to me like it is the flash from other cameras and cell phones causing the Auto White Balance to 'jump' to a different white balance. If you had manually set your camera's white balance to 'Daylight' I doubt you would see the pink.
VIP
That's what I had initially thought, too.  The second video clip, seems to dispense with the idea that flashes are unbalancing the Auto WB setting.  The pink is not uniform across the entire image.  It appears as pink streaks and blotches.
I missed the second video. Yes the streaking seems to rule out white balance.
New Contributor
Same problem with My 70d too. Have you solve the problem. Plase help.
powered by Lithium
