Reply
Highlighted
New Contributor
Canon 6d mark ii with canon 430ex ii speedlite
I have just update from 60D to 6D mark ii. With the 60D and my 430ex ii, i use godox cell ii-c to enable me get HSS. Now with the 6d mark ii, i am able to set the speed at 1/800 but when i press the shutter and the flash fires, there's no effect. The speed then show 1/180th. Is it that am not doing something right or the HSS transceiver is compatible.
Which HSS trigger will be help me now and in the future when i get strobes.
Please help me out. Thanks
Highlighted
Respected Contributor
Re: Canon 6d mark ii with canon 430ex ii speedlite
You should try to access the external flash menu on the 6DII to see if you can communicate with the Cell II-c by activating HSS using the camera, not the Godox transceiver.
There is a distinct possibility that the Godox Cell IIc is not compatible with the newer Canon camera such as the 6DII. It does not appear that Godox even has a firmware update for this unit so your option is limited. You might want to invest in the Godox wireless X system.
Diverhank's photos on Flickr
Highlighted
New Contributor
Thanks for the information. I appreciate
powered by Lithium
