Reply
Highlighted
New Contributor
Canon 60d screen(flip) not working but LCD screen on the top is working...............
My canon 60d was working very well...but from yesterday there is an issue with this......
Its flip screen is not working but LCD is working...
and no photo can be taken......
there is no battery issue.....
Highlighted
Esteemed Contributor
Re: Canon 60d screen(flip) not working but LCD screen on the top is working...............
The "info" button on the back of your camera controls what the LCD will display when using the camera.
But the "info" button causes the camera to cycle between several optional displays... including the basic shooting info, the cameras's built-in digital "level", etc.  ONE of the optional modes is to simply keep the display switched off.  The display would still work if you used the "menu" button.
Does the display light up if you use either the "menu" button or the "info" button?
If not then there may be a worn wiring issue (since the display is hinged and swivels it can wear out).  The good news is it is serviceable if that's all it is.
Tim Campbell
5D III, 5D IV, 60Da
Highlighted
New Contributor
no.... its not responding........ simply the LCD is working well...........
Even nothing is showing in "viewfinder".........
Highlighted
Honored Contributor
And the removable eyepiece on the viewfinder is solidly in place and not pushed upwards a little?
Bob
Highlighted
New Contributor
nope...........its properly placed.
Highlighted
Moderator
Hello govindarthi,
If the eyecup isn't blocking the IR sensor, the viewfinder is normal, and everything else seems fine, except the LCD screen isn't working, the next step is to send it in for repair.
If you're here in the USA, start the repair here on our site: http://Canon.us/xe47
Outside of the USA, head HERE to select your region/country and you'll find further support options from there.
powered by Lithium
