08-14-2015 07:11 PM - edited 08-14-2015 07:12 PM
Recently purchased the Canon 5DS, love it, but when have clickig to meter, it isn't coming up correctly, it will bounce all over the place, saying it's over exposed, then taking the photo it's exposed correctly, or I'll change either shutter, ISO, or aperture, to bring the meter bar to 0, and the photo is aweful, please help.
Gib.
08-14-2015 09:27 PM
08-17-2015 12:30 PM - edited 08-17-2015 12:31 PM
@dagibbo1 wrote:Recently purchased the Canon 5DS, love it, but when have clickig to meter, it isn't coming up correctly, it will bounce all over the place, saying it's over exposed, then taking the photo it's exposed correctly, or I'll change either shutter, ISO, or aperture, to bring the meter bar to 0, and the photo is aweful, please help.
Gib.
Hi Gib,
Not really enough info here for us to help you.
Reading your request it sounds as if the camera is exposing correctly in the auto modes (Av, Tv, P are auto modes). Yes, reflective meters such as are used in cameras tend to react rapidly to what's in front of them and the readings can appear to bounce around a lot in certain situations. But if your images in these auto expsoure modes appear correctly exposed, then it sounds as if the camera is working properly.
I'm guessing you switched to M or manual mode in order to change shutter/ISO/aperture, trying to center the meter readout indicator, when you say the photos are not exposed correctly. Not knowing you or your experience with DSLRs, SLRs, cameras or light meters in general, it sounds as if you are doing something wrong. Manual mode relies upon the photogapher and their judgment and experience to set the camera up properly to make a correct exposure.
While I suspect that it's just a matter of learning to use the camera, it's certainly also possible there's a fault with the one you got and you may want to get in touch with the seller. Sorry, but can't really help much more without more detailed info from you.
Alan Myers
San Jose, Calif., USA
FLICKR & EXPOSUREMANAGER
08-17-2015 06:42 PM
Gib.
If your metering is changing erratically it sounds like you are in 'Spot' metering mode.
Spot metering does just that meters a small spot, this means even small chnages in camera position can mean big changes in what is being metered off of.
Try changing the camera back to 'Evaluative Metering' for more consistant results.
