06-15-2019 12:04 PM
06-16-2019 07:08 AM - edited 06-16-2019 07:09 AM
Before you power it up again, remove the memory card. Turn on the camera. Turn off the camera. If the problem still persists without a memory card, then your camera needs to be serviced. Contact Canon Support.
If the problem goes away without a memory, obviously your memory card is suspect. I would try a new SD card. If you do not have a spare SD card on hand, then you should. I do not recommend buying a memory card on Amazon, because they seem to be flooded with counterfeit cards.
I only order cards online directly from a Canon dealer, or at a local camera dealer when I am out and about. Never use a micro-SD card with an adapter. The adapters make them unreliable. Always format a new memory card in your camera, too. I recommend name brands like Lexar or Sandisk. I recommend the Sandisk Extreme 32GB card for that camera.
06-16-2019 07:45 AM
06-23-2019 06:50 AM
