01-08-2021 12:28 AM
Hello:
I cannot turn off the AEB on my R5. When I try to use my main dial to urn off the three shots that are indicated (-1/3, 0, +1/3 ev) nothing happens. Other dials just move the ev to plus or minus exposures. Does anyone know why?
01-08-2021 06:43 AM
There is a menu setting that enables/disables AEB after you capture a shot sequence. Your camera must have it enabled. I think the default setting is Dean led.
01-08-2021 09:46 AM
@Waddizzle wrote:I think the default setting is Dean led.
Yes, that Dean, he is usually the ringleader when problems crop up.
01-08-2021 09:59 AM
01-08-2021 12:02 PM
@BillGates56 wrote:
I believe it is also taking HDR images. When I try to turn that off it gives me a message that I cannot do it because of the AEB setting. I cannot turn off AEB in the usual way. Got any solutions Dean?
LOL. Burnt by spell check again. Why won't it let you turn off AEB? ???
So, I asked Dean. He said, "Reset the camera back to factory defaults."
01-10-2021 12:35 AM
LOL! I wanted to give Dean a couple Kudos but I can't find his post . . .
01-10-2021 11:26 AM
I reset to factory and it worked. This is an unfortunate option since I will now have to go back and change many settings! I hope this doesn't happen often!
01-10-2021 01:51 PM
@BillGates56 wrote:I reset to factory and it worked. This is an unfortunate option since I will now have to go back and change many settings! I hope this doesn't happen often!
It clears itself, which is the factory default setting. If it does not do that, then that mean you went into the menu settings and changed it. You may want to explore setting up a custom shooting mode, where it does not automatically reset. Once done, you can switch AEB on and off by simply changing shooting modes.
