01-27-2018 02:40 PM
Hi All,
I recently switched from Nikon to Canon, and bought a new Canon 5DS along with the Canon 24-70 II 2.8 lens directly from Canon USA. For some strange reasons I am not able to get sharp photos with this camera and lense. Curious anyone else have the same problems, and more importantly how to adjust or correct it? The photos look sharp when not viewing at 100% sizing, however, when zoomed in at 100% it definitely not clear. To be clear, these photos were taken on stable tripod and timer, so no movement. I also using manual focus and live mode, thus I certain the photos were focused before taking the photos.
Any suggestions?
Thanks,
Lim
04-09-2018 06:34 AM
@limvo05wrote:Per the latest test I did the other night, it seems F8 seems to provide the sharpest image. Now, trying to figure out what is the optimal focus point for 24-70 when taking landscape? Have not had times to hit the field to test. Any recommendations? Thanks!
Use the center AF point
04-09-2018 11:33 AM
I think maybe he meant "What's the hyperfocal distance?"
04-10-2018 12:08 AM
You are correct. What I meant was the hyperfocal length at 24 and 70. Strangely enough, I tested a couple of DOF apps from Apple Itune, different apps with same settings yields different results. Not sure which app to trust? Thoughts? Suggestions?
04-10-2018 04:52 AM
@limvo05wrote:You are correct. What I meant was the hyperfocal length at 24 and 70. Strangely enough, I tested a couple of DOF apps from Apple Itune, different apps with same settings yields different results. Not sure which app to trust? Thoughts? Suggestions?
http://www.dofmaster.com/doftable.html
This one seems to be reliable. I frequently use it to select lenses before I leave out.
