07-02-2021 09:20 AM - edited 07-02-2021 10:09 AM
Tried going into the AF4 menu to set the M-Fn button for AF area. Won't accept it, and still stuck with the dial. Suggestions?
07-02-2021 09:27 AM
Hi, geneh!
So that the Community can help you better, we need to know exactly which Canon camera model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
07-02-2021 10:08 AM
1dx Mark III
07-02-2021 02:04 PM
Did you press "Set" after you dialed down to the option?
07-02-2021 03:04 PM
Yes, no luck,
07-03-2021 01:51 AM
Hi there,
On this camera you would typically have to press the AF Area button first (the button on the back of the camera, top right corner) and then the M.fn button would cycle through the options. Is that not happening with your camera? I'm referencing the info on page 326 down below for this.
07-03-2021 05:58 AM
If I am understanding the OP's problem correctly he is saying that in this menus option he can't change from dial to M.Fn button.
