03-10-2016 06:39 AM
03-10-2016 09:16 AM
I've already got EOS U 2 and 3 on my computer but neither are now seeing the 5D. I've found another way though, I simply take shots on the 5D, then put the card into the 5DSR and tether it to transfer the photos, seems to work.
03-10-2016 06:41 AM
03-10-2016 06:57 AM
Oddly, using a card reader windows doesn't recognise the card. Maybe it's bust?
I would like to tether teh 5D too though.
03-10-2016 07:38 AM
@boristhemoggy wrote:Oddly, using a card reader windows doesn't recognise the card. Maybe it's bust?
I would like to tether the 5D too though.
Is the problem in the card or the reader? And which version of Windows are you dealing with?
03-10-2016 10:17 AM
I have one Windows 7 Pro laptop that connects to my Rebel with EOSU-2, and my 6D with EOSU-3. All that I need to do is simply connect the USB cable, and turn on the camera. The appropriate utility fires itself up.
03-10-2016 11:20 AM
The card is fine, the card reader is fine. I use Windows 7 SP1 64 bit
03-10-2016 01:59 PM
"Oddly, using a card reader windows doesn't recognise the card. Maybe it's bust?"
"The card is fine, the card reader is fine."
I'm confused.
If you connect the camera via USB can you see it in the Computer window?
03-10-2016 02:18 PM
Sorry, if I use a card formatted in the 5D and put it in the card reader, Windows can't see it. If I use card formatted in the 5DSR and put it in the card reader, Windows sees it.
So I format the card in the 5DSR and use it in the 5D, then transfer using the reader.
That's not best though, and it means I can't tether. I am 100% certain I used to use EOSU 2 for the 5D but that can't see it now.
03-10-2016 02:32 PM
That sounds like a camera problem. What do others think?
03-10-2016 10:09 PM
It is definitely possible. I connected my 5D to my old laptop with Windows XP and it worked. 100% sure
