03-07-2016 01:43 PM
I'm trying to tether my 5D to Windows, but even EOS Utlities v2 won't see it.
Does anyone know what I need to tether it to Windows please? I'm trying to remote shoot.
03-07-2016 01:52 PM
I assume it works to transfer images. Have you tried a different cable?
03-07-2016 02:41 PM
03-07-2016 03:06 PM
Doesn't look like latest version supports 5D Mark I.
03-09-2016 12:48 PM
@jrhoffman75 wrote:Doesn't look like latest version supports 5D Mark I.
Or any member of the 1D series before Mark III. I think I'd be rather upset if I'd bought one of those puppies, given the prices they were charging for them then.
03-09-2016 12:52 PM - edited 03-09-2016 12:55 PM
"Tried 3 cables. It worked before I put the latest version on. " (Emphasis added)
Or check before you update to be sure the later software supports your device. The Canon site for the 5D doesn't show an update for EOS Utility.
03-09-2016 01:22 PM
If you are using Windows, you should be able to rollback an application update pretty easily.
03-09-2016 04:42 PM
@Waddizzle wrote:If you are using Windows, you should be able to rollback an application update pretty easily.
Yes, but that may not solve your problem. If you also have a more modern camera, you may want a more recent release of EOSU 2. While you can have both EOSU2 and EOSU 3 on the computer at the same time, you can't have two copies of EOSU 2.
03-10-2016 04:16 AM
I've already got EOS U 2 and 3 on my computer but neither are now seeing the 5D. I've found another way though, I simply take shots on the 5D, then put the card into the 5DSR and tether it to transfer the photos, seems to work.
03-10-2016 06:09 AM
If you have a 5DSr, then I assume that it uses EOSU-3. Roll back EOSU-2 for the 5D1.
