CameraWindow App not connecting to 6D
tonecj
Trying to connect the CameraWindow app on my iPhone 4 to a 6D without success.
I can setup the access point on the camera fine, and connect to it in the WiFi settings on my phone - but when I launch the app it just says "Connect the camera".
Any help would be awesome!
Skirball
Why are you using CameraWindow, why not EOS Remote?
8 REPLIES 8
Skirball
That will do it. EOS Remote works perfectly, thanks for the quick reply!
No worries.  Kudos for getting it up and running so quickly, I found it a little finicky at first...  but once you have everything set up it works pretty good.
Thanks
I use CameraWindow on the iPhone4s but it won't work on the iPad2 so I use EOS Remote on the iPad2. CW seems a little newer and smoother.
I have an iphone 5s and it also sees the 6d, but when I click the connect on the bottom of the phone nothing happens.  EOS remote works OK.  I thought since CW is newer it could be a better app.
I've got a 6D and an iPhone 4 with the EOS app.  Nonetheless, the phone doesn't recognize the camera.
hjcihak46,
Thank you for posting.
At what point during the connection process outlined in the Wi-Fi instruction manual that came with your camera does the connection fail?  Do you receive an error message?  If so, what is that error message?
I first downloaded the EOS app into my iPhone 4.
Then I followed all the steps for the camera (Wi-Fi on, etc.)
There were no error messages.  All I got when I booted the EOS app was that no camera was detected.
