04-15-2021 04:10 PM
So I got a new r5 and an rf 100-500 in anticipation of going to Africa later this year. I am a professional photographer that normally used 5d mk4s for my day-to-day workflow.
Long story short. Here is a picture I took this morning with the above r5 and rf 100-500 combo. Both have the latest firmware.
The background looks like someone used a smudge tool or the liquify/push tool to push and pull the texture of the background around. I opened this photo in dpp4 and in the latest lightroom. Both programs show the same effect.
I am attaching a small jpg that has only been slightly sharpened to show the effect, but the photo was taken as a cr3. image was taken at iso 800, 500mm, f9.0 1/1600 of a second. IBIS and lens stabilization are on.
Obviously, this is not a great photo, but if it was it would be ruined by the effect taking place. has anyone else had this issue. I could upload the raw file if anyone knows a server that will host such a large file. I assume this site will not.
Any ideas? As of now I am a bit disappointed with the camera lens combo for being such a high-end rig, I was selling my nature kit (nikon D810 and 150-600) to go all canon. I am unsure of that move now. There seem to be a few other issues with the camera that I'm not sure I can live with.
Anyway, let me know if you have any ideas on what is causing this.
Thanks
Dave
04-15-2021 04:24 PM
The only thing that immediately comes to mind is if you have dual pixel RAW enabled? I never used that feature myself, so don't know if it would ever lead to such output.
04-15-2021 04:46 PM
Hi Ricky. Dual pixel raw is not enabled.
I never use it either.
Dave
04-15-2021 04:55 PM
Are you a member of CPS?
https://www.usa.canon.com/internet/portal/us/home/support/canon-professional-services
You could take it up with them.
I don't see it in any of Ken Rockwell's images
https://www.kenrockwell.com/canon/eos-r/lenses/100-500mm.htm
04-15-2021 04:57 PM
Is this with or without DLO?
04-15-2021 07:34 PM - edited 04-15-2021 07:47 PM
04-16-2021 09:31 AM
Digital Lighting Optimiser, it is Canon's lens correction. You should be able to tun it on and off in DPP.
04-15-2021 07:46 PM
@kvbarkley wrote:Are you a member of CPS?
No. I'm not a member. I have considered joining a few times. I might have to.
04-15-2021 08:06 PM
You can see it up around the log in this one too. It has sharper areas and what sort of looks like motion-blurred areas and then some areas have a nice Bokeh. All of these areas are far behind the subject (feet) so it does not make any sense that there would be this inconsistency in the bokeh. I guess I will have to take this to canon because I don't find it acceptable. I've also noticed what seems like motion blur in slower-moving objects at 1/1600 of a second. Like some of the images have a double exposure look around the fish's eye, etc. Things that if taken with my other cameras would have been slightly out of focus but not streeked or motion blurred.
04-15-2021 07:24 PM - edited 04-15-2021 07:27 PM
Looks like you're using a UV or CPL filter, to me. If so, switch to a B+W Nano Clear filter. But, take test shots with no filter to see if removing any filter you might have been using makes any difference.
[EDIT] I have also seen a similar pattern when I had IS turned with the camera rig on a tripod, or when holding it very still.
