12-04-2015 02:38 PM
Ordered LP-E6 (original) battery for my 60D. Recieved a LP-E6N. Will that work or should I return?
12-04-2015 02:53 PM
Welcome to the Canon Forums and thanks for your inquiry!
The LP-E6N will work in your camera and charge with your exsisting charger. The only difference is the "N" version is slightly higher rating at 1865 mAh where the LP-E6 is 1800 mAh.
Hope this helps!
12-04-2015 02:53 PM
Hope this helps!
12-04-2015 02:56 PM
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
