06-25-2018 12:50 PM
Two Canon batteries provided w/camera when purchased as follows:
LP-E6N Lithium-Ion Battery Pack (7.2V - 1865mAh) - CHARGER: LC-E6 Charger for LP-E6 Battery Pack - EW-EOS80D
Batteries seem to lose charge during about an hour of use, don't fully discharge but status will show it's depleting. This happens even w/o lots/any flash use. Usually change them out before reaching about 1 bar.
Is there a better battery than what came stock with the camera, or some techinique if it's a memory problem w/battery?
06-30-2018 08:38 AM
@susaninnc wrote:Two Canon batteries provided w/camera when purchased as follows:
One hour does not sound right. Are you using the LCD screen a lot? Are you shooting video?
07-08-2018 04:05 AM
"Is there a better battery than what came stock with the camera, ..."
No, the Canon battery is the best.
Even the 80D manual suggests the battery life is dropped by 2/3 if you use the LCD and have wi-fi turned on. Don't use the LCD and turn wi-fi off and see if it makes a difference.
Video is another battery killer.
