07-19-2016 07:00 PM
Just recently the autofocus on my 70D does not alert me with the green light in the viewfinder or the beep. The problem exists in the creative modes only in basic modes it works.
I cleared all settings and functions and it still does not function.
Any help will be appreciated.
Tnx
marty
07-19-2016 07:20 PM
Are you in AI Servo Focus Mode?
07-19-2016 07:22 PM
no...one shot
07-19-2016 07:35 PM
clearing camera settings should reset BEEP, but check it in the Menu.
Verify lens in AF mode
Are you too close to subject
Remove and reinstall lens.
Just some random thoughts.
07-19-2016 07:49 PM
I did all the items you mentioned and still no luck.The camera is new to me and my knowledge is somewhat limited so I appreciate your help. It works fine in the basic modes but switch to M,AV,TV or P and its gone. Used the manual and went through all the autofocus settings and think they are all ok, but I could be wrong.
I was just up in New Hampshire and Mass. last weekend for a wedding. My son is a grad student at UNH in wildlife biology and environmental conservation.Currently doing genetic research on Bobcats. I love it up there!
07-19-2016 08:34 PM
@jrhoffman75 wrote:clearing camera settings should reset BEEP, but check it in the Menu.
I have tried to reset a camera back to factory defaults before, and not every setting seemed to reset. I need to try it again, but next time I plan to put the camera in green "A" mode, and then try to reset it .... in the two places, as noted above.
07-19-2016 07:54 PM
07-19-2016 08:01 PM
Thanks for your help John.
marty Carroll
Erie PA
07-19-2016 08:14 PM - edited 07-19-2016 08:25 PM
@irish626 wrote:Just recently the autofocus on my 70D does not alert me with the green light in the viewfinder or the beep. The problem exists in the creative modes only in basic modes it works.
Tnx
marty
You have to clear the camera settings in 2 places, one clears the camera settings, the other clears the Custom Functions. Be sure you have cleared both the camera settings and the custom functions.
07-19-2016 08:27 PM
Check this on Red Menu 1
