11-27-2018 07:30 AM
Hi, need a little help please, 5D mk4. Do I need to enable/configure autofocus in live view on the toughscreen. Doesn't seem to focus when touching the screen to focus on different objects at various focusing distances. Works perfectly on my 70D.
11-27-2018 12:38 PM
@yosser29 wrote:Hi, need a little help please, 5D mk4. Do I need to enable/configure autofocus in live view on the toughscreen. Doesn't seem to focus when touching the screen to focus on different objects at various focusing distances. Works perfectly on my 70D.
Two questions. What shooting mode are you using? Which, and how many, AF points are enabled? Test it in Green [A] mode.
There probably is a setting in th menus that can adjust the touch screen sensitivity, or even disable it. It is normally enabled in the bodies that I have with touch screens.
11-27-2018 12:44 PM
03-21-2019 09:08 AM
Found the cure for this problem by accident. Autofocus in live view does not work if you decoupled focus from the shutter release and enabled back button focus.
