Reply
Occasional Contributor
Accepted Solution
Apeture and Shutter priority not working
I've been shooting manual since getting my Canon 5D mark III and 60D cameras. TBut tday I'm trying out a friends Canon EF 100-400mm f/4.5-5.6L lens where the apeture will be changing with focal length for a sporting even and don't want to miss a thing so thought it would be a good time to try Apeture or Shutter priority, which both work effortslessly with my 60D but everything is VERY over exposed on the 5D in either of those priority settings. Is there something that I may have overlooked in one of the 5D's menus???
VIP
Re: Apeture and Shutter priority not working
Without knowing more info about your camera and exposure settings it is impossible to say what the issue.  We can only speculate, and tell you possibilities, things to check.
The first thing i would check would be the ISO setting.  Is it fixed, or AUTO?  Check metering mode.  Evaluative metering works great for sports action.
I shoot most action shots in Manual mode, with ISO set to AUTO.  This gives me a constant shutter speed, and a “constant” aperture setting.  Of course, depending upon your aperture setting at 100mm, it may change as you zoom out to 400m
Reputable Contributor
@CraackJackFlash wrote:
............ but everything is VERY over exposed on the 5D in either of those priority settings. Is there something that I may have overlooked in one of the 5D's menus???
The first thing I would check is the Exposure Compensation.
Mike Sowsun
80D, 5D Mk III
VIP
"The first thing I would check is the Exposure Compensation."
The first, first thing I would do is reset the camera.  This puts you back to square one.  Whenever something goes awry and you don't know why, it is good to get back to a known condition.  Reset it and try again.
Thanks kindly for your advice, Waddizzle. I will look into your suggestions this weekend
Thanks kindly for your advice, Mike. I will look into your suggestions this weekend
Thanks kindly for your advice, ebiggs1. I will look into your suggestion this weekend
[ Edited ]
I'm embarrased to say, I didn't even know about exposure compensation until now, and had to look up how to change it. I'm guessing its something you only use in priority modes, or, I just wan't payin attention, but both modes are now working as they should...THANK YOU, Mike!
powered by Lithium
