Reply
Occasional Contributor
AF won't lock in 7D Mark II
Canon 7D Mark II - used regularly for one year without issue; auto focus has worked perfectly.
Out of the blue, camera will not lock on subject using AF.
     Camera placed on tripod
     IS turned off
     Various lenses tried - same result
Camera keeps searching for focus; I can hear the "clicking" noise of searching, but it never locks on subject.
If I take a photo when the image seems "in focus" in the view finder, it is still not tack sharp, even with 70-200 f2.8.
There have been no incidents to jar or bump. I am the only operator and the camera has not left the house since it operated fine.  Wondering if I could have accidentally changed some setting? Any other possible explanation before I have to send it off to Canon?
VIP
Re: AF won't lock in 7D Mark II
[ Edited ]
Which AF focusing mode are you using, One Shot or AI Servo?  Have you tried a different lens?  Are you shooting through the viewfinder, or are you using LIve View?
Resetting the camera back to factory defaults should be either the first thing you do, or as a last resort if you do not want to lose all of your custom camera settings.
[EDIT]  Which AF point(s) are you using?  Try shooting at static subjects using just the center AF point and One Shot mode.  The only time my 7D2 has hunted for focus is when it either lacks sufficient contrast or sufficient light for focusing.
THanks for your quick response.
Generally, I use AI Servo, but switched to One Shot to see if that helped; it did not.
I tried three different lenses; it seems to be an issue with the camera.
I tried resetting to factory settings and that did nothing to help either.
Tried shooting at a still object with 70-200 2.8 and it was not as sharp as it should be. I think it is because it does not lock on the point, but instead seems to be rapidly waffling back and forth, in and out of focus.
VIP
Do you have an air blower?  If so, take a look at the AF sensor, which is located at the bottom of the camera box.  Use the air blower to blow out the entire mirror box.  Let's hope it is just a dusty AF sensor.  If not, I suggest contacting Canon Support.
Esteemed Contributor
Again, live view or viewfinder?
View finder, but I will try live view to see if the problem remains.
Tried blowing out camera box; no improvement.
Live view vs. view finder does not seem to matter either Smiley Sad.
Honored Contributor
Since LV and OVF use two entirely different focusing systems it seems like a trip to the service center might be warranted.
Check that the lens contacts in the mirror box are all fully out and don't stick if you carefully press them.Use a lens tissue or microfiber cloth on your finger tip to avoid getting body oil on the contacts.
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
powered by Lithium
