Reply
Occasional Contributor
90D Problem
YEs I know Canondoes not reconize third party lenses- However please read thru this-  I have a Tamron 18-400 lens that is 5 months old.  This lens worked perfectly for the 5 months. NO wthe lens willnot focus at 200mm or above.  I sent intheLens to
tamro- they retued in working ordere.  no mention of a problem.  Still des not work above 200mm.  There are countless( and I mean lots of 90D owners on Facebook that use this lens-  Now comes the real problem- This lens works fine on 4 different Canon bodies!! 7D MKII, 5Ti, 5D, another 90D( a friend).  My 90 D works with 8 Canon Lens + another Tamron,a Tokina, and a samyang lens.  I sent the body in for repairs to the tune of over #300 buck as it was out of warranty- It came backthe same way???  I don't think tey did anything to it as it worked with all Canon lenses??
Any one have any ideas what to try ??. It is a great walk around lens I can use it on my 7D MKII but the 90 D is much lighter and so I liket o use it on the  90D.
Thanks!
VIP
Re: 90D Problem
[ Edited ]
So, the camera works with every lens you own, except for this one Tamron lens?  Did you report this to Tamron?
You don't have a 90D camera problem.  You have a Tamron lens problem.  Maybe someon else in the forum owns the lens, and is experiencing similar problems with the 90D, too.  This is a pretty small group of users, relatively speaking.  I suggest you try a 90D social media group.
VIP
Re: 90D Problem
Welcome to the forum.
If I am reading your post correctly, you state that your Tamron lens works perfectly on a friends 90D but not your 90D.
If you switch to LiveView will the lens autofocus at FLs above 200mm?
If you manually focus the lens will you get green dot focus confirmation at FLs above 200mm?
Did you try resetting camera to factory settings?
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
Forum Elite
Re: 90D Problem
If you sent the camera to Canon, and I mean to a real Canon repair, not Canon store or shop someplace, they reset your camera so that is not the problem.  You are correct Canon  is not going to make your 90D work with a off brand lens.  A poor lens, IMHO, too. And, I suspect that is your problem.
Like my friend above stated, "You don't have a 90D camera problem.  You have a Tamron lens problem." And, I agree with him.
You said, "My 90 D works with 8 Canon Lens + another Tamron,a Tokina, and a samyang lens."  And Canon returned it in working condition. Again provided it was a real Canon authorized repair facility. I have run across some off brand lenses that just don't work on some cameras.  Probably because of poor quality control or whatever. I would press Tamron for a solution.
VIP
Re: 90D Problem
OP stated: " This lens works fine on 4 different Canon bodies!! 7D MKII, 5Ti, 5D, another 90D( a friend)."
VIP
Re: 90D Problem
Then I would compare the firmware revisions in the two cameras.
Esteemed Contributor
Re: 90D Problem
[ Edited ]
Not sure how helpful this will be:
If the serial number on your B028 is 077981 or earlier, you are likely running v1 FW
v2 FW adds support for EOS R and RP, but might include something additional not stated in the release notes by Tamron.
I am no stranger to 3rd party lenses... My walk-around is a Sigma.  I won't buy Tamron due to personal preference no matter how good, light, sharp images, etc  Focus ring moving backwards is one reason alone.  Muscle memory is important to me.  Compatibility issues between many of their lenses and bodies is much higher than other 3rd party lenses.  This is all a matter of personal preference and many of their lenses are very good.
You may want to look at what FW your 90D is running and compare with your friend's.  (same or different)?
If you are sticking with Tamron though and plan to buy other lenses from them, you might as well invest in the Tap-In adapter so you can update their FW.  If you need it just once, the $59 outlay is worth it.
TAMRON | Support
~6D2(v1.1.0) ~Many Lenses ~DxO PhotoLab Elite ~Windows10 Pro ~EVGA RTX 2080 FTW3 Ultra ~Pixma Pro-100 ~ImageClass MF644Cdw ~LBP622dw
Forum Elite
Re: 90D Problem
"OP stated: " This lens works fine on 4 different Canon bodies!! 7D MKII, 5Ti, 5D, another 90D( a friend)."
Doesn't make any difference to me.  The fact it works on one and not the other doesn't prove the lens is good.  That's why I said it could just be poor QC. Tolerance stacking if you will. Or, even, how the lens is beign used, we don't know. Maybe the OP tried to use it in different lighting than he did on the other cameras. Who knows?
"Then I would compare the firmware revisions in the two cameras."
If it went to a honest to gosh real Canon service center they most likely did a reset and a FW upgrade. Not too hard to check though. Canon is pretty through when they service a camera even beyond the complaint. If they said the 90D is good to go, it is not the 90D.
Forum Elite
Re: 90D Problem
"... invest in the Tap-In adapter so you can update their FW.  If you need it just once, the $59 outlay is worth it."
Great idea and I would certainly try it. Smiley Happy
Re: 90D Problem
There are noumrous Canon ownerson Facebook that use this lens no problem.
The. bigthing is this lens works perfectly on my 7D MKII, Another 90D(friend), a Canon 5D.  Lens was sent toTamron and checked under waranty.  UGHhhhh!
powered by Lithium
