Reply
New Contributor
80D - Busy - please wait.......
Hello,
I am getting this message when ever i take more than 3 photos, and when taking more than 5 images i have to wait for appx 15 seconds, before every image is saved, and then i can see the photos.
Usually on EOS cameras, you can view the images in a rough version, while the camera is saving them.
This has been the behavior on all the eos cameras i have used and know off.
Is anyone else experiencing this?
Best...Jan
Respected Contributor
Re: 80D - Busy - please wait.......
The buffer on the 80d is a bit shallow, I have read, but you should not be having that much trouble with the camera writing images to the card.
Are you you using an old slow card?
Have you formatted the card for the 80d?
What format are you shooting in?  Raw + JPG would fill that buffer up pretty quickly.
Scott
New Contributor
I am using the same card as in my 70D and 60D.
32gb Transcend Class 10.
And i know that the sensor is bigger, so therefore some bigger pictures (i am shooting RAW)
But the issue is more that usually while saving the images, you get to see a preview of the images.
But know that camera locks up completely until the buffer is empty, which is not typical Canon behavior.
Therefore i am hoping for a "secret reset" option, or a firmware update or some other trick.......
Best...Jan
VIP
[ Edited ]
"I am getting this message when ever i take more than 3 photos, and when taking more than 5 images i have to wait for appx 15 seconds, before every image is saved, and then i can see the photos."
Hmm.  Are you shooting single shot, or continous mode? As prevously noted, the 80D may have a limited buffer size, depending upon your file save format.  What are you photographing to create this "busy" condition?  We want to try to reproduce the circumstances.
Check which shooting mode the camera is in.  High ISO or long exposure compensation can cause delays under certain shooting scenarios.  Slow memory cards can also cause delays.  But, 15 seconds is a long time.
Esteemed Contributor
Or is the noise reduction on that takes a dark frame to look for hot pixels?
Maybe try a reset to default settings in Menu to rule out all the noise reduction/HDR/bracketing possibilities?
Scott
New Contributor
I have tried all of your great suggestions, but still have the problem ;-(
Just spoke to Canon, which suggested i send the camera in for repair.
So thanks for the help.
Occasional Contributor
Before you do that why dont you try aother memory card? The card could be failing. Also what is the number in the lower right corner of the viewfinder? That number tells you what the buffer is.
Reputable Contributor
I think the write speed of the 80D should be around 70-75 MB/s. The same as the 7DII and the 5Ds. Fastest write speed I have seen reported from a user was around 67 MB/s.
New Contributor
I purchase an external flash and place into AL Servo mode, and it resolved it for me "no more"  "Busy. I can now shoot multiple times without waiting.
powered by Lithium
