Reply
VIP
Re: 7D Mk2 Not Recognized by Windows 10
On fresh installs EOSU seems to default Wi-Fi or LAN mode. It seems unable to switch to USB by itself.
It needs a kick in the right direction. Even worse is that it does always make shortcut for EOS3. You have to go find it and start it manually.
Frequent Contributor
Isac:
Uninstall EOS Utility 3 - Reboot computer - and reinstall a fresh EOS Utility 3 copy.
Here are the steps to create the shortcut of EOS Utility 3 - on your desktop.
1. Hover your mouse on the Start icon (lower left bottom on your screen) and right click.On the sub-menu click on File Explorer.
2. Expand System (C) - (this usually is C:\) and expand Program Files (x86).
3. Expand the Canon folder. Expand EOS Utilty. Click the EU3 folder. The right pane will now show its content
4. Navigate to EOS Utilty 3 and right click to open the sub-menu.
5. Navigate to Senf to - and click on Desktop (create shortcut).
     An EOS Utility 3 Shotcut is now created on your desktop.
Connect your camera using the USB to camera cable. Start EOS Utillity 3 by clicking the shortcut.Download your files to the computer (set up where and what is to be downloaded on EOS Utility 3 program tabs).
Hope this helps.
Paul
I am not using the wi-fi card as mentioned in the OP
[ Edited ]
I have manually started the EOS Utilty 3 and ran it (Run as administrator) and this is the result. No Camera detected - all 3 options greyed out. I am giving up on this - it all seems too hard. I have spent enough time trying to get this to work - life is too short.
Thanks for the series of steps in your instructions - but not needed. I have been using Microsoft software since DOS days. I have written software, built and sold PCs since the 80's and given computer lessons to 100's of people. I do graphic art, photography and Photoshop editing. This problem is obviously caused by something unknown and everyone has been great at trying to unravel the mystery. I am leaning towards a Windows 10 glitch and hope they can get it sorted. Until then I am giving up on trying to fix the problem. Cheers!
Occasional Contributor
1; install all eps software onto computer
2; take out the WiFi card with the camera switched off.
3;attach computer cable from camera to computer
4;switch on camera
5; all should be well as this is also documented in the manual.... camera will NOT BE RECOGNISED with the WiFi card in the camera.
4;switch on camera
1; install all eos software onto computer
4;switch on camera
1; install all EOS software onto computer
4;switch on camera
4;switch on camera
powered by Lithium
