01-20-2015 04:24 PM
Here are 3 pictures taken inside the National Aviary in 2 different areas. All of them are taken with the Mk II with the Canon 100-400 and ISO is 4000. There has been no cropping or correction made to the images. They were taken within 30 minutes of each other with natual light. I also had an off camera flash available, but can't tell from the data if I actually used it.
The first is a finch http://www.rfyphotos.com/p850884880/h19d04730#h19d04730 at f 5.4 at 285 mm
The second is an ibis http://www.rfyphotos.com/p850884880/h19d04730#h202bebd at f 4.8 at 160 mm
The third is a warbler http://www.rfyphotos.com/p850884880/h19d04730#h86567ff at f 5.4 at 260 mm
Any thoughts or ideas would be helpful.
01-21-2015 10:19 AM
"Any thoughts or ideas would be helpful."
I may have missed it but you guys are shooting RAW? And your color space is AdobeRGB? You are using ACR to process?
I never shoot anything without those settings anymore. There just isn't any reason to shoot jpg any longer.
01-21-2015 11:06 AM
@ebiggs1 wrote:"Any thoughts or ideas would be helpful."
Why Adobe RGB? I thought the conventional wisdom was that Web sites and most printers are set up to use sRGB and that as a practical matter, Adobe RGB is useful only on printers that have been specially set up for it.
A RAW file isn't specific to a given color space, is it? I.e., you should be able to generate a TIFF or JPEG in either sRGB or Adobe RGB without losing any information that the gamut is capable of representing. Right?
01-21-2015 11:37 AM
Bob from Boston,
You are right! A RAW file has no color space. The ACR converter is where the RAW file get a color space assigned. I should have made it clear that this conversion is done by the converter. If you are shooting specifically for printing, AdobeRGB offers more range and versatility in the images taken.
Actually, to get the full benefit of shooting RAW, the output of the RAW converter should be set to a wide gamut format for transfer into Photoshop. If you're using ACR, you can also set it to 16 bit Pro Photo RGB. sRGB is 8 bit and restricts you to the color range that can be printed or even viewed on screen.
01-21-2015 12:44 PM
I only shoot in Raw using the AdobeRGB color space and process with ACR. I just sent it to the web as jpeg because that was what was needed for the website.
Fay
01-21-2015 03:02 PM
"I only shoot in Raw using the AdobeRGB color space and process with ACR."
01-22-2015 10:47 AM - edited 01-22-2015 01:09 PM
Most printers, yes, but that's because there are a whole lot of cheap printing shops out there (CVS 1 hour, Costco, Snapfish, Shutterfly, etc). But a high end print shop is going to use AdobeRGB or ProPhoto.
Of course, using it really doesn't mean squat if you don't have a wide gamut display capable of displaying AdobeRGB, calibrated, and you profile both the monitor and the printer/paper you're using, embed it in the final picture, soft proof, and then send it off to a high end print lab (or have a good inkjet at home, like a Pixma Pro or something along those lines).
But I think a lot of people just know that AdobeRGB is a wider gamut than sRGB, and therefore 'better'. And the majority use it without having all the details above, rendering it kind of useless. Of course, most of the photos end up on the web, where it's only displaying in sRGB anyway.
01-22-2015 12:12 PM - edited 01-22-2015 12:12 PM
But the question remains. The pictures I liked to. Are they grainer/noisier than I should expect with the Mk II? Or am I being unrealistic? I will gladly send a raw file to someone that can answer those questions.
Fay
01-22-2015 01:11 PM
@Fay wrote:But the question remains. The pictures I liked to. Are they grainer/noisier than I should expect with the Mk II? Or am I being unrealistic? I will gladly send a raw file to someone that can answer those questions.
Fay
Not unrealistically so. There are too many variables involved to say exactly how much (or how little) noise should be in a photo; but those are in the ballpark of what I would expect from a crop camera at ISO 4000 without any NR applied in post.
01-22-2015 02:01 PM
Drats. The pictures shown earlier in the thread looked so much better. Fay
