Reply
Honored Contributor
Re: 7D Mark II
@Skirball wrote:
@KeithR wrote:
Isn't it safe to assume that there's a reason why Canon explicitly recommends turning off IS on tripods; and that there's a reason why it has actually developed tripod-sensing IS on some of the big Whites?
Actually, no.  Look through your owners manual, you'll see all kinds of things contraindicated that most of us do every day with our cameras.  It's the nature of literature in a litigious world.
@KeithR wrote:
But here's some reading on the subject from Canon - hopefully authorative enough (and ten seconds' work in Google to find):
http://cpn.canon-europe.com/content/education/technical/image_stabilization_lenses.do
When using certain early models of IS lenses with a tripod it was necessary to turn off the IS function. This is because of a phenomenon known as ‘Shake Return’. Shake Return occurs when the IS system tries to correct vibrations to which the system itself contributes. When the IS lens sits on a tripod, the IS detection gyros pick up any tiny vibrations or movement; these might be caused by the tripod being knocked, or the photographer adjusting a camera setting.
The IS system then swings into action to correct that movement. The movement of the IS lens group causes its own minute vibration, which is in turn detected by the movement sensor, which triggers another correction. This ‘feedback loop’ can continue endlessly, resulting in the addition of unwanted blur to images that would be sharper if the IS function was switched off.
Thanks, sarcasm aside.  That's interesting.  I trust that the Canon engineers are better engineers than I.  But I'm surprised that something that seems like simple feedback isn't avoidable.
Well, I guess it is, since the problem seems confined to "certain early models of IS lenses". Now if we could just find out what those models are - and whether any of them are still in production.
Bob
VIP
Re: 7D Mark II
Easy!
Everything that does not have the tripod sensor.
Respected Contributor
Re: 7D Mark II
Actually, I looked it up just for grins.  For the 24-105L IS and 24-70 f/4 IS it recommends turning off IS while on a tripod to save battery.  The 70-200 II, 300mm 2.8 II, 400mm 2.8 II, 200-400mm f/4 1.4x, 800mm 5.6, says "depending on the tripod and conditions sometimes it may be better to turn IS off".  A non-commital statement if I've ever read one.  Only the old 100-400 says not to use it; the new manual isn't up yet.
The link you provided was of course from Canon EU.   I perused Canon USA's extensive webpage on IS and couldn't find any mention of it.  My point simply: the situation isn't as clear cut as you make it out to be.
Re: 7D Mark II
I couldn't find an official list, but the ones I saw were the 100-400 (assumed that the new one does not), original 75-300, and the 300 f/4 IS.  I also saw some people mention that old versions of the 24-105.  However, based on the experiences they report - which were quite significant - and my experience with my 24-105 I'd say they definately fixed it.   Which is why I came to the same conclusion I did last time I looked into this: if you can't see an issue, then I doubt you have an issue.
Super Contributor
Re: 7D Mark II
You need to turn off first generation IS like my 300L F4 IS. You can actually see the image move around in the viewfinder. My 24-105 - second gen does not as it detects when it is on a tripod. I have taken many night shots and forgot to turn it off and got great resutls.
For what you are doing I'd shut it off no matter which generatiion IS you have, use mirror lock up and and remote if you can so there is no vibration. I purchase Focus Tune about a year ago but just used a flat target. Yesterday I ordered the MKII traget. How are you finding the system works?
Esteemed Contributor
Re: 7D Mark II
If you are using a stable platform there is no need for IS so turning it off eleminates any potential problems it may introduce.
Fay
Occasional Contributor
Re: 7D Mark II
Well let's just say I just took the camera body back and exchanged it for a new one. I think the system works, but my components didn't. Blaming camera at this point, since the lens works with other cameras.
Before using the system make sure you watch the videos. There is no instruction in the box on setting up your test. I found the software helps more than eyeballing the results.
Good luck.
Fay
Fay
Re: 7D Mark II
Okay it isn't the camera. In fact it was the lens that was the problerm. I talked to Canon Tech Support we attempted several things including manual focusing the equipment. One thing the tech asked is how long the lens was on the previous camera. Short answer was almost constantly for the last several years with occassional change. We were left with the suggestion that we send the lens and camera to the service center. His question regarding the length the lens was on the question brought the thought up about the condition of the contacts. After some research I bought Deoxit Gold and cleaned the lens contacts.
We also got a better system down working with the LensAlign target and the Focus Tune v3 software. While running these new test we made sure that the IS was off. The bottom line is that our problem is resolved. Yahoo! But, weather is crapping. Boo. So looking forward to some shooting weather.
Thank you for all of your comments and I am sorry it took me time to get back here to tell you "the rest of the story."
Fay
Re: 7D Mark II
This is very useful information, and something most of would never think of.
New Contributor
Re: 7D Mark II
[ Edited ]
Just to make sure I got the gist of your final results, did you find that all of the image softness issues were resolved by careful micro-adjustment with each lens?
I recently took my 7D Mark I to the camera store and did a side-by-side comparison with the store's 7D Mark II, using the same lens (18-135mm IS STM), the same memory card, and the same settings on both cameras. (By "same lens," I mean the exact same lens, transferred from one camera to the other.)
When I got home and compared the images, I was disappointed by the softness in the Mark II's images compared to what I saw from my Mark I. My Mark I's images were clearly noisier than the Mark II's at ISO 6400, but the lines and edges in the images were much sharper from my Mark I.
After that test, I started to think that maybe I didn't want to upgrade to the Mark II after all. I'm still not sure, after reading how much work you went to in fine-tuning the microadjustments of your lenses, so I'm very interested in hearing your thoughts now that you've done all of that.
Thanks!
powered by Lithium
