08-06-2018 09:50 PM
Hi Everyone,
I'm new to the forum, hoping to leverage your expertise in helping me find a solution to a problem I'm having a Canon 7D. I recently replaced the shutter on this camera and being a newbie to camera repair, I did not discharge the flash capacitor before doing so. At one point during the repair, I accidentally touched the discharge point on the flash circuit board (CY3-1754-000) with my tweezers, which caused a spark. After assembling the whole camera, it wouldn't turn on and the battery icon would flash on the top screen.
I replaced the flash circuit board with a new one (including new capacitor which had to be soldered on). After this, all functions worked properly, but the flash would not engage. It would pop up, but wouldn't fire, and the camera would shoot off an Error 50 (Electric Control Malfunction). I replaced the flash assembly itself, but am still getting the same error.
Things I've done to troubleshoot since then:
- Reseat all the cables that I disassembled during repairs
- Measured capacitance on flash capacitor (270uF) as well as on the smaller one next to it (310 uF)
- Measured resistance between yellow connector pin and flash capactor (-), as well as red connector pin and flash capactior (+), both of which were around 0-2 Ohms, so there is a connection there.
- Measured voltage in flash capacitor right after trying to fire flash. Measured 0.5V
- Checked resistance between various IC pins and compared with previous damaged board. All values are more or less the same
Not really sure how to proceed further. Don't want to throw money into another new flash circuit board, especially if the issue isn't with it. Any help would be greatly appreciated. Thanks!
08-06-2018 10:17 PM
Hi, dimsh2000!
We just wanted to let you know that we don't recommend do-it-yourself repairs. It's best to let a professional Canon Factory Service Center Technician do the work to keep you and your gear safe.
To start your repair process, you can complete a Repair Request on our website.
Thanks!
08-07-2018 06:40 AM
You need to measure the voltage across the main capacitor before attempting to fire the flash, when charged it should be around 250-300 V. If it isn't reaching this voltage then it must be a fault in the charging generator on the board.
As the previous post suggests you shouldn't play with this unless you know what you doing but according to what you have done already it sounds as though you are competent, just be careful, that 300 V hurts when it goes up your fingers.
08-10-2018 08:45 PM
Any idea what the charging generator on a board like this looks like? Or the chip PN? I found a component LV8401, which a motor driver, but it seems to be working fine. There's also a 20AAJ IGBT for Strobe Flash which seems to be working fine as well.
08-10-2018 11:39 PM
Found the root cause! The flash circuit board that was sent to me was faulty and was missing an oscillator. Without an oscillator, the flash won't fire. Going to open a case with the buyer and get a replacement. Thanks for all your help!
