Reply
Highlighted
New Contributor
Accepted Solution
70D using Diffuser - Flash button press does nothing
I have used my diffuser on my old XSI for years and when I went to try it on my new 70D the camera Flash seems to disable. When this is install in the hotshoe and I try to press the flash button, nothing happens. Soon as I remove it the button works.
Highlighted
Esteemed Contributor
Re: 70D using Diffuser - Flash button press does nothing
Not sure I understand the situation but IF you install something into the hotshoe it presses down a switch to prevent the built in flash from popping up. If it tried to pop up there would be a problem because something SHOULD be in it's way.
Highlighted
What is this thing called "Diffuser" is it something on the pop-up flash?  can you provide a link?
Highlighted
New Contributor
Highlighted
I think Cicopo is right, the camera thinks there is something that will block the pop-up flash and keeps it retracted. You might be able to figure out where the switch is and modify the diffuser to not hit it.
Highlighted
New Contributor
Thanks for your input. I'll give it a closer look at those contact points.
powered by Lithium
