08-11-2018 03:18 PM
Hi everyone. My 70D is not fully powering up. The top display turns on and operates, the autofocus and viewfinder display also work but the LCD doesn't turn on and it doesn't take pictures when the shutter is fully pressed. Has anyone experienced this issue and can you share how it was solved?
08-12-2018 02:02 PM
@Nestor wrote:Hi everyone. My 70D is not fully powering up. The top display turns on and operates, the autofocus and viewfinder display also work but the LCD doesn't turn on and it doesn't take pictures when the shutter is fully pressed. Has anyone experienced this issue and can you share how it was solved?
Contact Canon Service and Support.
08-12-2018 03:57 PM
In additionn... Canon finally came clean on the 70D PCB failures... so if you are experiencing or about to experience a problem caused by a "defect" which is what this was.. you might have coverage avaialble to you. Contact Canon like Wadizzle states.
~R5 C (1.0.6.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10
~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8 ~CarePaks Are Worth It08-12-2018 06:40 PM
Hello Nestor,
There are a few troubleshooting steps I'd like to help resolve this issue. We'll reset the camera, which should restore it to a default state. These steps should clear out the memory and thereby any errors which may be present.
- Anything attached or installed in the camera — memory cards, the lens, the battery, battery grips should all be removed.
- Once the lens is off let's check it using the steps below.
a) Clean the lens contacts* to restore connection with the body.
*Warning - Do not clean lens contacts on either a Canon lens or the camera body with an eraser! It's easy to rub off the gold plating on these contacts and end up with data communication problems! Our strong recommendation is to use a soft, clean, micro fiber cloth. Please do not use anything abrasive.
b) Try using a different Canon EF series lens. It doesn't have to be the same focal length as the one you were using.
c) If you are using a third party lens, we recommend discontinuing its use. There can sometimes be communication error related issues with third-party lenses. Ensuring that you're using a Canon lens eliminates that as a potential factor in the error.
If the issues seem to persist the next step would be to send the equipment to Canon for service.
You may fill out an online repair request form at the following link to setup your repair using our online service.
https://www.usa.canon.com/internet/portal/us/home/support/service-repair
08-12-2018 09:35 PM
Thank you all for the replies. I tried cleaning the lens contacts on both the body and the lens but it did not help.
I have 2 other Canon bodies (5D and T3) and can confirm the lenses are working properly.
I will send it over to Canon for service.
08-13-2018 09:42 AM
" I tried cleaning the lens contacts on both the body and the lens but it did not help."
It never does or rarely anyway! I have been in cameras for five decades and I bet I have not seen this work twice.
08-13-2018 09:43 AM
"I will send it over to Canon for service."
Good idea, this is where it belongs.
08-16-2018 01:29 PM - edited 08-18-2018 07:37 AM
I think you should take it to the service center. Don't play with it 🙂 I love my talking tom with unlimited money
06-04-2019 10:38 AM - last edited on 06-04-2019 10:42 AM by Stephen
Yes, take it to Service Center. And they will fix it. like [Removed link per Forum Guidelines]
04-09-2019 10:36 AM - last edited on 04-09-2019 10:40 AM by Porcha
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
