Reply
New Contributor
[6D] stop the GPS battery drain with the OFF switch
PLEASE someone tell Firmware team to make the 6D STOP draining battery while OFF.
I noticed that even while the camera is OFF (Hardware Switched OFF) the GPS is still draining to battery.
Respected Contributor
Re: [6D] stop the GPS battery drain with the OFF switch
Yes, this is what everyone was hoping they'd fix with the first firmware update.  Seems they decided to pool their resources and tackle that horrible issue with the Date/Time/Zone values resetting themselves.  Glad they got that fixed.
Reputable Contributor
I want this feature and the White Balance button so bad.
http://forums.usa.canon.com/t5/EOS/6D-GPS-Drains-battery-when-idle/m-p/13439#U13439 you can bump the thread there.
Weekend Travelers Blog | Eastern Sierra Fall Color Guide
No doubt about the white balance button.  I don't use GPS so it doesn't bother me, but I just think it's sloppy engineering on Canon's part and I think not fixing it shows their apathetic corporate side.
New Contributor
great thread ... let's hope this is fixed in the next FW upgrade
Frequent Contributor
Me three.
New Contributor
OFF means OFF Smiley Happy
Occasional Contributor
6D battery drain - "Work Around"
Install the Canon Battery Grip.
Step 1.  Turn the battery lock to Open.and leave it unlocked
      (Batteries are now disconected from camera)
Step 2    Use a rubber band to hold battery tray in.
NOTE:: If Canon will not make a fix, possibly the after-market suppliers of the 'Grip' will make a three position latch.
A 'Modified' grip could easily be manufactured by modifying the tray and latch assembly.
Position 1.  Power disconnected and tray locked in (6:00 clock position)
Position 2.  Tray unlocked (Similar position as present)
Position 3.  Tray is locked and power is connecd. (Same position as present and battery drain will continue as it does now..)
GET WITH IT CANON....   or let the after-market fix it with their 'Grip'
Bill
don't worry, Canon will fix some translation error in the next firmware release.
The Magic Lantern (http://www.magiclantern.fm/) is said to have this feature, but I have not tried it myself.
Gee... pretty annoying having to use a 3rd hack for a $2000+ camera, just because Canon don't know that OFF means OFF.
When you turn the camera OFF, often you put it away some place where there is no GPS coverage, for example inside a house or in the trunk of a car, so it really makes no sense burning battery to look for GPS, with the disadvantage that next time you try to turn the camera on, there is no battery left.
Canon should really fix this in a firmware upgrade; also for the 7D Mark II that has the same annoying problem.
powered by Lithium
