Reply
Frequent Contributor
Re: 6D gave me really blurry photos?
Yes, that is the EXACT same issue I have when I use that camera.  Unless I take photos outside in bright sunlight, I get the same "fuzziness" at different parts of the image.
I contacted CANON about this issue however, at that time, they said they had never received complaints like this before.  I was starting to wonder if only MY camera was defective.  Clearly, not as you have showed the same issue as me.  I regret purchasing this camera because I cannot trust it on shoots.
Good luck.
VIP
@AnaNera wrote:
@AndreaW wrote:
This is the EXACT same problem I am having with my new Canon 6D Mark II camera.  I never had this issue with my Canon 6D camera, therefore, the issue is not the lenses I am using because I tried using 3 different lenses and, unfortunately, had the same result -- fuzzy-looking photos.  Smiley Sad
Would this be a camera defect?
I have the same problem, photos end up looking horrible. This is one of the fuzzy photos I got.fuzzy.JPG
It is strongly suggested that you send your camera and lens that you used here to Canon for checkout and repair.
New Contributor
I know it's been about a year at this point, did you ever figure out the issue? I am having the exact same problem and it is extremely frustrating and the people responding on here sound a little rude and condescending when they genuinely do not seem to understand the issue. Like you said, I did not have this problem on my other camera it has absolutely nothing to do with skill. It almost looks like the camera is trying to smooth out the photo itself and it completely takes away any quality in the photo. I really really want to like this camera but that issue is making it so hard for me to and I haven't seen a single helpful comment, it's just people being insulting. I don't want to sound ungrateful, I get that people are just trying to help but I genuinely believe this has nothing to do with the way the photos are being taken. The fact that we are only having this problem on this camera specifically should tell people it is not the photographer. If anyone at all has figured it out please help!
Unfortunately, I was never able to resolve the issue and did not want to re-send my camera back to Canon since they did not see anything wrong with it the first time and, more importantly, had never heard of such an issue with the 6D Mark II.  The camera performs well outdoors in bright environments.  But yes, when you take pictures indoors, unless it is a brightly lit environment, it is almost as if the camera attempts to over-compensate by smoothing out the image to the point to where it leaves "fuzzy" areas in the image.  There is no correcting that.
By the way, thank you for acknowledging the poor behavior of some of Canon's contributors on this thread.  That, too, was disappointing since those of us who are experiencing this issue are legitimately trying to resolve the issue, but instead were met with insults.
Good luck to you.
Respected Contributor
Were your other cameras full frame cameras?
On a sunny day, use AV mode set your camera to f/16 go outside and take a photo. When you do that are you still having an issue?
VIP
In that sample it appears you set focus on the person with the child and red coat. DOF will not keep the person in front of her or behind her in sharp focus.  You stripped most of the exif data so I can not tell what your exact gear or settings were. However you saved the jpg at a 79 instead of 100 quality setting.  All these things do not point to a camera/gear problem.
VIP
Keep in mind the camera does not make the image. The lens does.  A camera is basically just a storage device that captures what the lens saw. The sensor in a 6D Mk II has high enough resolution to capture pretty darn good images from what the lens tells it do.
Thank you for the explanation.  But here's the thing, I have used 3 different lenses using various settings with the 6D Mark II camera and yet I still get the same "fuzzy" result in my images.  Yet when I use the 6D, also using the same various lenses in the same indoor environment, I never get the "fuzziness" in my images.  That is why I believe the issue is with the 6D Mark II camera itself, and not with the lenses.
VIP
"That is why I believe the issue is with the 6D Mark II camera itself, and not with the lenses."
The nearly 30% higher resolution sensor is going to display different IQ's for the same lenses. I still lean towards a DOF issue and not a gear problem.
Can you post a sample of both under as nearly the sane conditions with the exif intact and jpg set to 100? Basically what I am saying is a great lens will show better IQ on a higher resolution camera (6D Mk II).  But a marginal lens, or poor lens may show an even worse IQ on a higher resolution camera. This might account for the difference you are seeing between the two cameras.  The old saying resolution is not always the solution.
If the 'church?' shot was with a large aperture, then I can confidently say the issue is with DOF and the 79 jpg quality setting.
What post editor do you use?  I use Photoshop/Lightroom but you can also use the free DPP4 from Canon.  One very important post editing setting you should do is lens correction.  I do this on every single photo I shoot.  It is automatically applied upon import into Lightroom and or PS.
VIP
A single-pixel on a sensor of any size pretty much has infinite depth of field, however it is not possible to have all of the other parameters so fixed. This presents a relationship between DOF and the pixel's parameters.  In other words the measured DOF is not changed but the perceived DOF is.
powered by Lithium
