06-06-2014 06:47 AM
err30 ?
What's does that mean and how do I fix it
06-06-2014 09:22 AM
Error 30 is undefined on my 1 series cameras and I suspose it is on the 6D, too.
What lens did you have on it. If it is a 3rd party lens, that is the problem. Try a new SD card or low-level format it.
Charge the battery. Do all the 'normal' stuff as one may be at fault.
06-06-2014 10:38 AM
If this article is applicable to your camera then you need to call Canon support: http://www.learn.usa.canon.com/resources/articles/2012/eos_error_msgs.shtml
According to the article, an error 30 indicates a problem with the shutter. This is not likely something you will be able to clear yourself.
