02-07-2016 08:36 AM
02-07-2016 09:14 AM
Does the LCD go black only in video mode ? If it works in liveview shooting or if it works to display menu etc, you may see if the lens cap has been removed or if the exposure settings are correct.
02-07-2016 09:37 AM
02-07-2016 10:24 AM
Press the DISP button.
02-07-2016 01:21 PM
02-07-2016 09:24 PM
try the info button. Or carry it to a local camera store and ask the people there.
02-08-2016 09:13 AM
On the the 5D II that button is labeled DISP. Oddly, Canon labels it DISP on some models and INFO on others.
02-08-2016 01:50 PM - edited 02-08-2016 01:51 PM
@TCampbell wrote:On the the 5D II that button is labeled DISP. Oddly, Canon labels it DISP on some models and INFO on others.
The INFO button on my 6D toggles between three screens, one of them is the built-in level. It also changes the display format when playing back saved images, when the camera is in image playback mode.
On entry level Rebes, like a T5, the DISP button shows just one screen that shows the status of the camera, but it also can be used to turn off the LCD screen when the camera is in other modes. Likewise, the DISP can toggle between display format during image playback.
Basically, the buttons provide similar functions, but the INFO button provides a bit more.
02-09-2016 09:06 AM
it says info on mine.
I figured out what the problem was and it will show how much more i have to learn.
I plugged the mic into the av out. It makes the lcd screen go blank.
I learned a lot trying to fugure this out!!
02-25-2016 02:24 PM
That is because the internal LCD goes black when you view the video on a screen. HDMI does this, too.
