Reply
New Contributor
5D mark iii-- ac adaptor for BG-E11 battery grip?
Hi, I am newly into a 5D mark iii. I have the BG-E11 extended battery grip. On my old 1Ds I also had the battery grip and it came with an extra sliding drawer, which attached to the ac adaptor. I am having a heck of a time searching for the same for this new configuration. I see the ac adpator one would use without the battery grip-- with a single battery sized piece which would slip into the single battery slot. Can someone please help me with identifying an ac adaptor for the battery grip? Thanks.
VIP
Re: 5D mark iii-- ac adaptor for BG-E11 battery grip?
I do not think Canon makes AC Adapters for 5D battery grips.  And, if it is not made by Canon, then I would not truest it.  I think you are out of luck.  The 1D bodies are designed differently from the 5D bodies.
New Contributor
I got the answer elsewhere. You can use the ACK-E6 ac adaptor. You slide it into the first slot in the BG-E11 and use a little rubber opening through which you funnel out the cord.
VIP
So, that must be what the little rubber flap by the "door" on the battery grips are used for....to feed a power cable into it.
powered by Lithium
