06-18-2013 09:49 PM
06-21-2013 02:09 AM
06-22-2013 12:09 PM - edited 06-22-2013 12:14 PM
If it's a Mark II, Custom Function III, 4: AF/Drive Superimposed Display set to "1. Off" will turn off the red flash of active AF points. You'll still get the green LED of Focus Confirmation and hear the "beep", if it's enabled, but both these only occur in One Shot mode (or when AI Focus is using One Shot... there is no Focus Confirmation in AI Servo, since focus is continuous and never "locks"). Reset that C.Fn to "0. On" and you'll see the red AF point flash at focus start.
Note: during AF Point selection, the chosen point(s) should light up red no matter which way C.Fn III, 4 is set.
I'm not sure if the original 5D is exactly the same, but it is probably very similar (there were not much, if any, changes to the AF system from the original to the Mark II) .
Alan Myers
San Jose, Calif.
amfoto1@aol.com
GEAR: 5DII, 7D(x2), 50D(x3), some other cameras, lenses and accessories.
