Reply
Highlighted
Frequent Contributor
Re: 5D duplicating images
[ Edited ]
@angeladeagan wrote:
I haven't resolved my issue yet.   When I am downloading photos to my computer I take out the either the SD or Compact Flash.    I'll let you know if I have any success.
Cheers
First, I know nothing about Mac OS. However, I just did a quick GOOGLE and found a web site called OS X DAILY that describes this problem and its resolution. Something to do with "Photo apps" and a tic box to turn off duplicates. [edited] I might have missed something in your OP, so I don't know exactly how you are transfering, i.e., using this app (or others) or just looking at your card, which is the way most of us do it in Windows. Some use the EOS Utility and some, like me, use a built in or USB 3 card reader and "file explorer" to copy/move images [end edit].
<removed link per forum guidelines>
I hope this helps.
FD
Highlighted
Occasional Contributor
I did unclick "Copy items to the Photos library", but it still imports two copies of the image.
In any case, this fix wouldn't explain why I get only one copy when I take the second card out, would it?
(Even though there is demonstrably nothing on the second card...)
Cheers,
t
Highlighted
Cheers,
t
Thank you for the report, t. As for the second card being removed, no it wouldn't expain it to me, but I don't know the ins and outs of the Mac OS. From your comment, I take it that you are connecting directly to the camera. Have you tried just accessing the card either in a reader (USB or built in)? Are the files being automatically coppied to separate folders? I assume the latter based on my use of Windows. It will append the file name if you copy a file with the same name to the same folder or ask you to overwrite/skip. Accessing the card only would exclude the camera as the problem.
I know, maybe obvious questions, but somestimes we / I overlook simple troubleshooting steps Smiley Happy
FD
Highlighted
I did get the SD-card to read in the my MacBook Pro (15", mid 2012). There is only one copy of the photo in the card. Then again, this might be analogous to removing the other card before importing from the camera, which also causes Photos or Preview to see/import only one copy (even though the second card is empty!). I don't get the same issue using Photos with my Canon 7D mark ii. Seems like it might be an interaction between MacOS and the Canon 5D mark iv... (For a while MacOS did not have support for Canon 5D mark iv, and I can't use iPhoto like I used to with the 7D mark ii, because while MacOS eventually supported 5D mark iv's RAW format, iPhoto is no longer being updated.)
Thanks for your help!
t
Highlighted
[ Edited ]
t
When you copy those files straight from the card, do you get duplicates after the copy? Just curious. I do understan that the card shows no duplicates, just curious if you end up with duplicats after the copy/move and if to seperate folders.
FD
Highlighted
No, importing from the SD-card reader yields only a single copy, whether I just do a single image (select and chose "open with" into Photos) or mount the SD card reader in Photos and chose "Import all new"... Seems pretty analog to mounting the camera with just a single card in it...
Highlighted
Thanks, t. Sorry for the odd questions. I am not that familiar with Mac OS, but I am a retired systems/IT admin (Windows and Linux) and have had to troubleshoot Mac in a limited copacity. I'm not so sure that mounting your camera would be similar to mounting a USB or built in card reader, especially since you mentioned that Apple didn't support the 5D mark IV for a while.
FD
Highlighted
New Contributor
MY ISSUE IS RESOLVED.
The duplication occurred only when I had cards in both slots, even though I was only writing to one card. I DID A MARK IV firmware update and it resolved the duplication when connecting USB to import, even if I have both cards in slots and only using one.
Highlighted
Thank you. I hope this helps others. Sometimes we tend to overlook the dreaded, but needed, firmware updates.
FD
Highlighted
Thank you.
Cheers - Angela
powered by Lithium
