Reply
Occasional Contributor
Re: 5D Mark IV firmware 1.2.1: Cannot import pictures from Canon to my iPad Pro 2018 iOS 13.1.2
thanks
i "of course" also opened a similiar thread on apple side
from my understanding the way canon shows the dual slot to apple is not compatible
not sure which side should act for compatibility - and thats the main problem why its never solved on those problem
each side is pointing to the other :/
Valued Contributor
@SpiderWoW wrote:
thanks
It's actually not that uncommon, especially in the climate of changing standards to improve software security.  We can only wait for the two sides to come up with a solution (hopefully soon) and to work around that.
"All the beauty of life is made up of light and shadow", Leo Tolstoy;
"I have never been able to enlarge a photograph... I am just interested in the shots" Henri Cartier-Bresson
Honored Contributor
Dual slot is not relevant with a Rebel however.
And dual slot 1D X does work with iOS12.
1D X, Rebel T5i, Many lenses, Pixma PRO-100, MX472, LRCC Classic
Valued Contributor
Good point. Still, I think it is a coding issue unless someone has a specific suggestion. If that is so a workaround while they nut it out seems like the best plan.
i hope so much this is fixed sometime
but my hope vanishes since the problem exists since i have the ipad
Honored Contributor
I now have access to my iPad.
If I connect the camera via USB to the Lightning connector and turn the camera on, nothing happens, unlike erlier iOS where the Photos app opened.
But, if I go to the Photos app on the right hand side of the bottom of the scren it says Import, and if I slect that the images on my dual slot 1D X are imported.
Unplug the camera and Import goes away. Reconnect camera and it appears.
Valued Contributor
You're a legend John! {;-)
Honored Contributor
We'll have to wait to hear from SpiderWoW to see if it is a unique bug for that particular camera.
thanks for testing, but...
when i have tried this the import button was NOT showing up
i also opened the photo app manually if it was not opening automatically
and as mentioned the usb device/cam does also not show up in the files app
like other cams / devices do
the 1d might be a different story (for sure software is different)
what ipad / ios are you using ?
Honored Contributor
iOS 13.1.2 on 10.5" Pro.
Photos doesn't open when camera is connected.
Camera doesn't show up in Files.
powered by Lithium
