10-27-2017 03:24 PM
Hi. Love my 5DMK4. Has anyone noticed that when the ST-E3-RT transmitter is in hot shoe and engergized, the exposure simulation in Live View does not render properly. If one turns the ST-E3-RT power off (while still in the hot shoe) then the exposure simulation works properly. Any thoughts, suggestions, or workarounds? This is a real pain when shooting in the field.
Thanks, Matt D
Canon 5DMK IV
Canon 5DMK III
10-27-2017 05:18 PM - edited 10-27-2017 05:21 PM
@mdaugher1811 wrote:Hi. Love my 5DMK4. Has anyone noticed that when the ST-E3-RT transmitter is in hot shoe and engergized, the exposure simulation in Live View does not render properly. If one turns the ST-E3-RT power off (while still in the hot shoe) then the exposure simulation works properly. Any thoughts, suggestions, or workarounds? This is a real pain when shooting in the field.
Thanks, Matt D
Canon 5DMK IV
Canon 5DMK III
Not sure what you mean by not rendering properly? with respect to what? ambient light? predicted remote flash light? It will try to do the latter. If you just want to see the ambient light, you should turn the RT off...to me that seems to make sense, considering it's "exposure simulation"...
10-27-2017 08:53 PM - edited 10-27-2017 08:54 PM
I have a similar problem when I put anything on the hotshoe, even if it's not flash related.
And I assume when in the field he's trying to use 'exposure simulation' to expose for the background then use the flash as fill on the subject. Yes you can turn off your transmitter (altho when I used an off brand transmitter just turning it off doesn't help, I actually have to take it off the hotshoe) but why should you have to?? QUite annoying and time consuming when you want to be fast and economical on a shoot.
Surely it can't be that hard to fix this issue with a firmware update. I've played around with the three Exposure Simulation options (Enable, enable during button press, and disable), and none of them help.
Please fix! Most vexing, and definitely the most annoying issue with my 5DMK4.
10-28-2017 06:37 AM
I do not think that there is anything wrong with your camera.
Live View mode is not compatible with the use of flash. Live View uses a different light metering system compared to using the viewfinder. AFAIK, Live View metering is not configured to work with the intelligent flash system.
10-28-2017 08:48 AM
@Waddizzle wrote:I do not think that there is anything wrong with your camera.
I think that may be news to Canon. Both the flash chapter and the live view chapter of the 5D4 instruction manual mention using flash with live view.
10-28-2017 09:31 AM
LOL. I am sure you are correct. I had problems with using my flash a couple of years ago in Live View, and gave up on using it.
10-28-2017 10:04 AM
Okay, this other thread describes circumstances that I think I had once upon a time. It didn’t work as expected so I just used the viewfinder.
http://community.usa.canon.com/t5/EOS-Rebel/Built-in-flash-malfunction/m-p/222868#M19609
I, too, had had ExpSim enabled while using Live View and the built in flash. This current thread has problems with the remote transmitter in combination with a remote flash. But, in all cases, we were using Live View, ExpSim, and a flash. I do not think that they play well together.
10-28-2017 06:22 PM
Hi. Yes, I was attempting to use LiveView to exposure for the ambient--much like many of the mirrorless EVF's do. The issue becomes when I turn the Canon ST-E3-RT transmitter on, then the exposure for the background completely changes to the point that the ambient exposure being simulated is not even close to actual. Changes to flash power does not change this result.
Definelty believe this is a problem Canon has not heard much about. Hopefully, only a firmware issue.
Thanks all for the valuable feedback.
Matt Daugherty, CPP
10-28-2017 08:09 PM
@mdaugher1811 wrote:Hi. Yes, I was attempting to use LiveView to exposure for the ambient--much like many of the mirrorless EVF's do. The issue becomes when I turn the Canon ST-E3-RT transmitter on, then the exposure for the background completely changes to the point that the ambient exposure being simulated is not even close to actual. Changes to flash power does not change this result.
Matt Daugherty, CPP
Uh, huh. What is your shutter speed before and after you turn one the ST-E3-RT transmitter? What is the fastest available shutter speed both before and after you power it on?
Have you tried turning off ExpSim? The camera can focus and measure the exposure in one of two ways, when using Live View.
10-28-2017 09:05 PM
Waddizzle, thanks. I will test turning ExpSim off and report back shutter speed tests. I really appreciate your feedback.
