Reply
Highlighted
Esteemed Contributor
Re: 5D Mark 3 Shutter Release or Self-Timer Mystery
That is bizarre.   You may want to call Canon support to inquire about that.  You've done a good job pin-pointing the issue.  The Sun does put out nearly as much energy in infrared as it does in visible... but I would have expected the camera sensor wanted to see a very specific sequence of IR pulses... not just IR wavelengths in general.
While I don't often enable the IR sensor ... I don't recall the sunlight being an issue on my 5D III.
Tim Campbell
5D III, 5D IV, 60Da
Highlighted
Occasional Contributor
I've never enabled the IR sensor!
Highlighted
You mentioned that you use the 2 second delay mode.  That mode also enables the IR sensor.  Any of the "delay" modes enable the IR sensor.   If you look at either the 10-sec or 2-sec timer options they have a symbol of the IR remote next to them.
If you use the 2 sec. delay mode to allow the camera vibration to settle down when shooting with a tripod then this also enables the IR sensor.  If you use a "wired" remote shutter release you can use the instant mode (since using pressing the shutter button on a wired shutter release wont shake the camera.)
Tim Campbell
5D III, 5D IV, 60Da
Highlighted
That explalins why the IR sensor would be enabled.  However, I have used a wired shutter release before and the camera shutter fired on its own using it, as well.  At the time, I thought the problem was the cable remote (which was brand new and Canon brand), but this problem with the 2-second timer and IR sensor would seem to indicate the two conditions are related.  I'm relatively certain I would not have been using the self-timer with the cable remote.  As you said, it wouldn't make sense.
Does using Live View have any connection with the IR sensor?  Chances are fairly good that I switched to Live View in all circumstances before tripping the shutter, whether using the cable remote or the self-timer.
In any event, this certainly can't be normal behavior.  I know I'm not the only 5D III owner who uses the 2-second timer on a tripod in the sun!
Bev
powered by Lithium
