06-27-2020 12:59 PM
The mount adapter ef-eos m does not work properly with two Canon EF lenses: the 50mm F/1.8 II, and the 50mm F/2.5 Compact-Macro.
The Canon M50 body with mount adapter ef-eos m does not focus properly with these lenses except at close distances. Infinity focus, and focus at distances of about 50-75 feet with both lenses and the mount adapter ef-eos m is not possible, producing out-of-focus images.
Is there a solution?
I used the EOS utility to try to install lens profiles for these lenses on the EOS M50, but I'm not sure if they were properly registered in the camera body - or if there are actually working lens profiles for EF lenses adapted to the M50 body with the mount adapter ef-eos m.
I would be grateful for any help, as these are wonderful lenses, and they focus at all distances brilliantly on the Canon 6D.
Note: My other EF lenses, the 135mm F/2 L, and the 24-105 L IS USM, both work very well with the adapter at all distances.
06-27-2020 01:09 PM
I suggest that you contact Canon Support about this.
06-27-2020 01:49 PM
