Reply
Highlighted
Occasional Contributor
Accepted Solution
1:1 aspect ratio not 1:1
[ Edited ]
Why is the 1:1 aspect ratio saved in RAW as a different proportion? I am tried of having to crop it back to 1:1? Does it make a difference in RAW which asprect ratio is selected?
Thanks in advence,
Bill
Highlighted
Moderator
Re: 1:1 aspect ratio not 1:1
Hi, Bill!
So that the Community can help you better, we will need to know exactly which camera you're using, the software you're using to edit your photos, and the computer operating system you use (Windows Vista, 7, 8, 10, or macOS).
If you're in the United States, and this is an urgent support need, please click HERE to enter your product information and discover your support options.
If you're outside of the USA, please click HERE to find support options in your country.
Thanks and have a great day!
Highlighted
Canon EOS 80D
using EOS Utility 3 to import
Editing in Mac Photos.
Highlighted
VIP
@boodabill wrote:
Canon EOS 80D
I suspect that Mac photos is the problem.  Are you saving the files as JPG format?  Why don’t you use the Canon DPP application? Can Mac Photos process RAW files?  If not, I suggest that you try saving the files as RAW, and use DPP to process them.
Highlighted
No they appear with a larger than 1:1 ratio on the camera and in the EOS Utility once imported before I import them to Photos on Mac....
Highlighted
VIP
You did not answer my questions.  So, I will suggest that you read page 146 in the Instruction Manual on setting Aspect Ratio.
Highlighted
[ Edited ]
I save them as RAW, like I posted originally.( i want to edit in Photos and Lumix.)
As JPEGs they are also larger than 1:1
Highlighted
[ Edited ]
Ok thanks, i got the answer from the manual:
RAW images
The images will always be saved with the [3:2] aspect ratio. The selected aspect ratio information is added to the RAW image file. When you process the RAW image with Digital Photo Professional (EOS software), this allows you to generate an image with the same aspect ratio set for shooting. In the case of the [4:3], [16:9], and [1:1] aspect ratios, the lines to indicate the aspect ratio will appear during image playback, but they are not actually drawn on the captured image.
Highlighted
VIP
Aspect ratio is a term that describes the dimensions of an image.  It is comparing the width to the height and expressing it in the form of a ratio. The aspect ratio of your images is primarily determined by the fixed physical dimensions of your camera's sensor. It is easier to crop in post.  If your camera doesn't have an aspect ratio selection, it is the only way to do it.
powered by Lithium
