06-13-2016 08:22 PM
I was looking into buying a t5i, but the 18-55 kit lens, I found has a very short focus throw, but sense it done electronicly I was wondering if I can change it in the settings or with majic lantern.
06-13-2016 08:26 PM
06-13-2016 08:49 PM - edited 06-13-2016 08:50 PM
@myname wrote:
I plan on using this mostly for video.
Canon EF lenses are focused mechanically. The 18-55mm kit lens does not focus electronically.
If you are looking to use a DSLR mostly for video, then I advise investigating other features. Does the camera have an audio input for an external microphone? Can the camera perform autofocus in video mode? How much control over the exposure does the camera allow in video mode? What range of shutter speeds and ISO values available in video mode? Can I control the aperture during video mode? And on, and on.
Remember, a T5i is a still camera, first and foremost, which just happens be able to record short video clips.
06-13-2016 09:00 PM
If it's the STM version of the lens it is electronically focused. Even in manual focus mode the camera has to be powered on to focus.
06-14-2016 12:06 AM - edited 06-14-2016 12:07 AM
Exacly my point so then can you controll how sensitive the focus ring is, if it's done electronicly?
06-14-2016 04:23 AM
@myname wrote:Exacly my point so then can you controll how sensitive the focus ring is, if it's done electronicly?
Negative. First and foremost, the lens is mechanically operated. For lack of a better term, the lens is a "focus by wire", electro-mechanical system. Turning the focus ring controls motors, which in turn control mechanical gears that move the lens elements.
While the sensitivity of the focus ring is electronically calibrated to cause the focusing control gears to turn at certain speeds, the sensitivty of the focus ring is fixed on this model.. The sensitivity of the ring is fixed, just as if it were turning a fixed gear.
06-14-2016 05:37 AM
are there lenes that have that, or a longer focus throw in that price range, with image stabization?
06-14-2016 07:39 AM - edited 06-14-2016 07:41 AM
"If it's the STM version of the lens it is electronically focused. Even in manual focus mode the camera has to be powered on to focus."
There may be gears in side the lens but it must have power to operate. It won't focus at all off of the camera or on it if the camera is turned off. That is what John Hoffman meant.
Whether that makes any difference I don't know. Magic Lantern will have no effect on this. It is the way the lens is made.
06-14-2016 07:43 AM
"I was looking into buying a t5i ..."
IMHO, any Rebel makes a poor video camera. If video is your main most thing, get a real video camera and not a DSLR.
Rebels are still cameras that do video. They are not video cameras that do stills.
It is one reason I never did or got into video.
06-15-2016 03:18 AM
I'm not talking about mechinaicly focused lenses I'm talking about lense that have a focus by wire ( as in turning the focus ring send a signal to focus then lens). going by some of these post I should make it clear that theres no reason it can't do what I'm asking if it dose I'm only asking if it allows you to change it, as in did cannon make a way for setting this, or did majic lantern do it.
