05-06-2015 09:19 PM
My Rebel T2i has a problem where the display is blank. The backlight comes on but no menu or fonts of any kind. Wondering if anyone has had this problem and how it was fixed. Lots of people with this issue but no results that I could find. Probably not worth sending in to repair since the cost is almost what the camera is worth?
thanks
05-07-2015 01:56 PM - edited 05-07-2015 01:56 PM
Ed refers to the fact that the "Info" button will cycle through a series of optional things you'd like to have displayed on the LCD... and one choice in the cycle of possibilities is to display nothing at all (display would remain off).
BUT... pressening the "Menu" button should always bring up the Menu (even if the display is normally off, it'll come on to display the menu.) (Provided the camera actually does have power and is switched on.)
If it's not coming on ... ever... then something is broken that only service can fix.
05-07-2015 08:39 AM
The LCD is turned off. Turn it back on.
05-07-2015 08:48 AM
05-07-2015 08:52 AM
05-07-2015 02:00 PM
Yes, that seems to be the case. Any idea how much this would be to get serviced?
05-07-2015 03:09 PM
Almost nothing is under $200 bucks.
