01-19-2017 02:29 PM
Just got a new T5i, after taking a few pictures I tried to view them on the camera. Every few pictures I get one that is small on the screen and an error message "cannot playback image". What is that all about?
01-19-2017 03:35 PM
Sounds like a bad card. Did you low-level format the card in the camera?
01-19-2017 10:48 PM
Well, I finally realized I had not formatted the card with the camera, have done that, snapped a few shots and so far so good!
I sure hope the problem is solved that easy.
Thanks for the reply.
01-20-2017 06:12 AM
Carolann1
Just to be safe, replace the SD card. Formating the card may just have been a false fix. If the SD card worked with some images but no all, is probably not a format issue. Don't take the chance because it will show its ugly head when you least want it to.
